My 2018 M3 LR (18k miles) stopped charging and I'm not sure what to do next.
For 5 years I had been using a 15amp circuit to charge the car with the mobile connector.
A few weeks ago I had a dedicated 30amp circuit installed, and it worked well for ~11 days. On that 11th day, after coming home and plugging the charge cable in, I received a notification five minutes later on the app that charging suddenly stopped.
I didn't think much of it, but the next day I noticed the green light on the mobile connector was off. And then I noticed the 30amp breaker was tripped. I reset the breaker, but it tripped immediately. I unplugged the cable from the car, reset the breaker, plugged in the charging cable again, and it tripped immediately. I tried setting the charge rate to lower amps, but it still tripped. I then tried switching the mobile connector from the new 30amp circuit to the 15amp circuit I had been using for 5 years. The 15amp circuit didn't trip, but lights on that circuit dimmed and the car showed an error.
I drove to a supercharger for further testing. It wouldn't charge on 2 different stalls and I got an error.
I opened a service request, they did a virtual diagnosis, and I received an estimate for $2.4k to replace the PCS.
After in-person diagnosis, the technician said "Found phase A in the PCS is faulted and preventing full charge rate." They said the vehicle charged on a known good high power wall charger at 32amps but not 48 amps, and that it charged normally on all wall connectors and mobile chargers at the shop. They also said it didn't fault while supercharging (not sure if they're referring to the logs of when I tried supercharging or when they tried supercharging while it was in their possession). They noted that in addition to the PCS failure, my mobile connector could have gone bad, which could explain the 30amp breaker at my house tripping.
The shop said that if I'm okay with charging at a lower rate, I don't need to replace the PCS at this time.
I'm okay with charging at less than 30amps and would probably defer the $2.4k to the future and pay just the diagnostic fee for now.
Questions I'm thinking about:
Thank you.
- Why is the vehicle charging at the shop, but not at my home on 2 different circuits nor at that supercharger I tried using before bringing it in for service? (Perhaps my mobile connector went bad, but why didn't it charge at that supercharger?)
- Did they perform some sort of software or hardware reset which could have theoretically enabled the vehicle to charge again at their shop? (I asked them this question two days ago and still waiting for a response.)
- Did both the PCS and my mobile connector coincidentally fail at the same time? (Assuming the mobile connector went bad, did one failure cause the other?)
- Did the new 30amp circuit cause the failure, or just expose a PCS issue that had already been happening? (The straw that broke the camel's back)
- Should I retake possession of the vehicle and try charging at a supercharger, and if that works, try charging at my home again?
- The car has been off a charger for 2 weeks now (38% battery currently) and is still in the shop. Can this harm the battery?
- Should I bite the bullet and pay the $2.4k to get the PCS replaced?
- If I get the PCS replaced, and the mobile connector is indeed bad, is there any risk of a bad mobile connector harming the PCS?
- And of course, why isn't the PCS considered part of the high voltage battery (for warranty purposes)? I'm at only 18k miles, but past the 4 year basic warranty point.
Thank you.
