You might have a rare but possible problem with 14.19kW of solar, and 2 Powerwalls. The Powerwall has a 5kw power rating (in/out). If you're producing 14.19kW from solar, and you're grid connected, then that excess 4.19kW above the combined Powerwalls rating of 10kw will go out onto the grid. No problem. But, if you're off-grid, and it's a bright sunny day, the Powerwalls will not be able to handle that power and I believe they will shut down in that situation.
They will not adjust frequency to shut down solar production like they do in high state of charge situation. At least that's what I've been told, and kind of makes sense.
Ideally you'd match the solar capacity to the Powerwall capacity.
Also, I did a week-long test of off grid and made a YouTube video on it. (CWNE88 is the channel name)
I’m very curious about this “mismatch” topic... I have a little over 10 kW solar and will be installing a single Powerwall (referral reward). You’re implying that I’d need two PW installed to prevent shutdown when the solar is generating more than 5 kW...or should this discussion be in kWh? Confused.
