Sucking carbon dioxide from air is cheaper than scientists thought claims
If it's really possible to make jet fuel from atmospheric carbon dioxide for $3.79/gallon, why isn't that happening right now? The cheaper FBO at Hawthorne CA is listed as currently charging $4.82/gallon at AirNav: KHHR - Jack Northrop Field/Hawthorne Municipal Airport
Carbon Engineering’s design blows air through towers that contain a solution of potassium hydroxide, which reacts with CO2 to form potassium carbonate. The result, after further processing, is a calcium carbonate pellet that can be heated to release the CO2. That CO2 could then be pressurized, put into a pipeline and disposed of underground, but the company is planning instead to use the gas to make synthetic, low-carbon fuels. Keith says that the company can produce these at a cost of about $1 per litre.
