I missed the part where I argued with myself, and I think you missed several parts I disputed that you wrote. LOL.
You said: “Pressing the button on the J1772 does exactly the same thing that pressing the button on the Tesla connector does”.
This is false.
You said “When pressed, the car will stop drawing current in a fraction of a second,
faster than you can pull the plug out.”.
This is false.
You said: “There's no reason for the port to lock on the J1772 adapter when it's in by itself”
This is false.
... and I’m not “insisting” on pulling the plug and adapter separately. I’m insisting that it’s safest to stop charging before pulling anything out to avoid many possible issues. The latch lock could break or
already be broken, so you might *think* you are pulling the adapter out with the plug but you aren’t.
Safety first.
“Totally unnecessary”? Sure, the same way seat belts are also “totally unnecessary”. You should only use them the trip you are going to get into an accident, and not any other time.
I can’t argue with that. (and you don’t have to go into the car, you can use the app before you get to the car).
So to recap your “technique is to press the J1772 button, release it, push the connector in to reengage the lock, then pull them out together all with one hand”.
The problems with this are if the resistor supposed to be triggered by the button is faulty or the button is otherwise faulty, you won’t signal the car. If you then remove just the plug it could arc. If you then try to remove both together it could stop you if the latch mechanism isn’t broken, causing you to use my safer method anyways (stopping and unlocking with app or car). If the latch mechanism is broken (or breaks when you pull on it) then you’ll
think you are pulling both the plug and adapter out but you will be leaving the adapter behind. If you noticed the charge didn’t stop you could save any arcing, if not ... arcing.
INSTEAD, the safety first approach ...
If you always stop charging and always use two hands (pull the plug with one hand and hold the adapter with the other), you won’t be bitten ever by a faulty J1772 resistor or latch mechanism (as I just described, there may be other ways to get bitten
... but feel free to do it the way that’s prone to unsafety, and only revert to the safe method AFTER you encounter an issue ... hopefully the issue fails safe without damage done.
I will continue to use my seat belt every trip, and stop charging via Tesla before unplugging anything.
