Charge port unlocking - Scheduled charging
Hi TMC forum
I just took delivery of my new Berlin made Model Y Standard Range.
The car is swapping out my old Model 3 which I charged on the same charger (an Easee Home).
The issue is as follows:
I have scheduled charging enabled in the car (not on the charger and none 3. Party apps controlling anything).
Whenever i plug in the charge cable, the port in the car locks straight away and the charge port light turns blue.
After a around 5-10 seconds the port unlocks and turns white.
After around 5-10 seconds more, the port tries to lock again with no succes as the previous unlocking has made the charge cable come slighty loose (at least just enough so the charge port lock cant engage again).
Do any of you guys have any idea what is causing the charge port to act this way only when scheduled charging is enabled?
It is not happening with the mobile charger that comes with the car wierdly enough.
