Are there any specs on the amps the outlet puts out? How long to charge that ATV? How much battery drain while charging large items and will the outlet cut off at a certain percentage of drain? I doubt I will be able to run my Mig Welder
I have a dedicated 50 amp circuit off of my fuse panel so about 11 kw
This would be cool.If Tesla got serious about using the battery to its full potential, they'd find a way to divert the drive inverter's three phase power to a high amperage outlet or interface of some sort.
Where is the pedantic emoji?The Cybertruck will not have a 220 outlet. It'll have a 240 outlet.
This is how I would imagine RV camping at full hookups.The RV is plugged in to my Truck, and the truck is plugged in to the RV Electrical hookup. Truck charges, while supplying power to the RV.Any thoughts on whether one could daisy chain charge another car? Run the 14-50 or wall charger to the cyber truck and then run one of the outlets on the truck to a Model 3, for example? This might help people wanting two electric cars but having limited charging options or driveway/garage space constraints.
This is a nonstarter idea. Even if you were to use one of the 3 phases, the delivered voltage would be ~400V AC. Not compatible with any electrical gear you can buy.If Tesla got serious about using the battery to its full potential, they'd find a way to divert the drive inverter's three phase power to a high amperage outlet or interface of some sort.
If the inverter can't vary the output voltage, incorporate a step down transformer maybe? I'm not an electrical engineer..This is a nonstarter idea. Even if you were to use one of the 3 phases, the delivered voltage would be ~400V AC. Not compatible with any electrical gear you can buy.
Honestly, it's easier to include a dedicated 240V invertor than try to press the motor invertor into this job. The motor invertor is high voltage, variable frequency (and almost never 60Hz, like power distribution), and designed to drive a completely different load than normal appliances. A dedicated invertor is also cheaper, and much lighter, than a high power transformer. It's truly trying to hammer a square peg into a round hole to get the motor invertor to do the job of supplying 240V/120V appliances.If the inverter can't vary the output voltage, incorporate a step down transformer maybe? I'm not an electrical engineer..
Maybe so, but here's a whole whitepaper on exactly this topic: IEEE Xplore Full-Text PDF:Honestly, it's easier to include a dedicated 240V invertor than try to press the motor invertor into this job. The motor invertor is high voltage, variable frequency (and almost never 60Hz, like power distribution), and designed to drive a completely different load than normal appliances. A dedicated invertor is also cheaper, and much lighter, than a high power transformer. It's truly trying to hammer a square peg into a round hole to get the motor invertor to do the job of supplying 240V/120V appliances.
