Well, 120V (not 110) or 240V (not 220).Please be advised that "30 Amp" has different meanings. In an RV park, where one might look for 14-50 outlets and expect 40 amp 220 volt power, "30 Amp" means 110 volt, or 3.3 kw per hour. A true 220 volt 30 amp might be what you'd get from a J1772. But don't look for it at an RV park.
USA uses 120/240 (or 208 in some commercial locations.)
Some other countries still use 110/220: Mains electricity by country - Wikipedia, the free encyclopedia
- - - Updated - - -
I think rectified is when converting AC to DC. They would do that inside the charger in your car, or inside an external fast charger like the supercharger.Interesting. So my house has 2 phases but the power was rectified( I think that is the opposite of what I mean?) in the transformer or at the plant?
but there are two phases running on the power lines ? so why split one, and huh? I should probably just get my EE and learn all of the other stuff that isn't Chem/Civil/Culinary/fun
Many devices run on DC internally, so have small "rectifiers" inside them. But a whole house rectifier would be unusual. Very few places distribute DC around the building.
Having split-phase AC service provides a way to get the 2 power levels to your house. For high powered appliances (e.g., dryer/heater/welder/oven) they use the two hot wires to get 240V. For most of the other devices (TVs/lights/etc.) they use one hot + neutral to get 120V. Since there are two different hots they tend to split them into different circuits so half of the house gets one of the "legs" and the other half of the house get the other "leg". If you use a volt meter with a really long extension cord you can find that there is 240V potential between the hot side of outlets from different parts of the house (when you find the two legs).
Most houses are served by a "step down transformer" (frequently on a pole) that takes higher distribution 3 phase (like ~440V) and steps it down to the split phase 120/240V. In some cases, one of the step down transformers may serve more than one house at once.
