Hi there! I'd like to setup a discussion regarding possible capping when battery full. I have noticed on my MS 85D the max voltage on cell level to be 4,1V. In SMT I have nominal cap 67,1kWh, but I can achieve only like 64kWh therefore (96% max). I have done a range test under 90kph, 0°C on a flat highway and could achieve almost 350km and pulled 60kWh out of the pack. I tried also calibrate the battery following all tips I could find without any success - it still ends on 96%.
I tried charging till the end on AC and also on SCH with the same result - voltage never exceeds 4,1V level. Then I watched videos from Bjorn Nyland with his MS P85 (MF), he achieves voltages like 4,18 - 4,19V. Therefore I think, this might add approx 10% more SOC. But I have noticed him to be using SW 10.2 2020.48.37.1 but I have 2020.48.37.8 as actual.
Is this the reason the voltage is lower?
I'm not disappointed by the battery state, it now seems I simply can't fully charge it, therefore I think I can afford to charge it to almost full (like 90%SOC) everytime without any potential damage. Just curious whether the voltage cap is common for all vehicles with this SW revision or not.
Thanks a lot for your tips or experience.
