Koolio46
This is exactly what I did. Had an existing 20amp circuit in my garage (was used only for the garage door opener), had an electrician change it to a 240v / 20amp circuit with the 6-20 outlet, and moved the garage door to the 15amp circuit (used for the lights and 2 other outlets in the garage).This. I swapped my mother's 5-15 outlet with a 5-20 when delivering her Model 3 last year, and it's been fine for her. (Garaged, 20-75 miles/day on average.) It doesn't seem like a big jump going from 12A (1.4 kW) to 16A (1.9 kW), but it's a 33% boost, and more like a 50% jump in actual energy delivered to the battery since the ancillary energy costs (fans, computers, etc) are fixed. 100% of the additional power goes to the battery. If your home has a 20A breaker and 12ga wiring, it's a 5-minute job to swap the outlet.
Caveat: know what you're doing, use a $10 outlet tester to check your work, and ensure that if this is a circuit with multiple outlets on it, you don't actually use the other outlets while the car is charging. If you're unsure but you think it'll work (you have a 20A breaker), hire an electrician for one hour to verify and swap the outlet.
Prior to this, I was using the 5-15 outlet (110v) for about a week and the increased charging speed is def noticeable. The speed is just right for me since I don’t drive every day.
I only went this route because my panel is in my condo two floors up from my garage so it would’ve been super expensive to add a 40 or 50amp circuit...plus, the fact that’d I’d have to ask my downstairs neighbors if they’d let the electrician punch some holes in their wall to run some wiring. Lol
