For my 2c: Back when i was driving my P85D coast to coast US in 2015, before supercharging, I had to carry around a heavy connecting cable I had acquired, and handling was always an issue, so I had it in a 'portable' roller.
You have given me 2 ideas.
1. A welder supply shop, but with a 3x6gauge and 1x8gauge so I can upgrade it (and my outlet/breaker/wiring) to a 14-50 in the future.
2. or just buy a 14-50 100' (which seems a lot more available) with an adapter to the 10-30 and limit the charge to 25-30A
So, I did go to a welding shop. The very wise proprietor took a look at me and at the car, asked to read the manual instructions for charging, and said: not an exact quote but close "look, you don't want to handle 100ft of that thing. You'll be charging overnight, mostly, at hotels or wherever, right? Why not use a commercial 75ft cable and limit your charge to 30amps? You don't need more overnight." So, I ended out buying a common 30amp commercial cable at Home Depot. Never needed more. Not even coast to coast.
In the end I managed to install a change at my, then, condominium home. That was 208/23 when I was lucky. Oddly that is just fine, charges overnight as much as I ever need.
So, unless you have very unusual needs I suggest skipping the high power if you can charge overnight. You'll never really need it. FWIW, when I did it people thought I was crazy because my car coupled handle 240/80 so that should be what I feed my car. Never have I needed that much except on road trips, and now there are Superchargers for that.
My apologies if I have offended by offering a different choice. It's a dozen years of EV driving that makes me convinced that probably is overkill.
