Hi Tesla Community,
I'm planning a road trip in Colorado and will be staying at a mountain cabin Airbnb. The nearest Supercharger is 2 hours away, and I need to figure out a way to charge at the Airbnb to avoid anxiety about charging.
1. Can I use a 240-volt dryer outlet for Level 2 charging of my Tesla?
2. What type of adapter will I need for this setup?
3. Any safety tips or considerations when using a dryer outlet for charging?
4. Has anyone had similar experiences and can share how it worked out?
The regular 120-volt outlet charges too slowly, and I don’t want to worry about running out of charge because we will be using the car throughout the day. Any advice or recommendations would be greatly appreciated!
Thank you!
Yes, if you have the Mobile Connector. You may need a suitable 240-volt extension cord to reach the vehicle from the laundry. They never seem to design houses with this in mind! Check places like Walmart for RV accessories, they have a small selection of extension cords and adaptors too. I made my own from buying AWG 8 multi-stranded 4-wire cable by the foot from Home Depot and the plug/socket I needed and wired it myself.
Most dryer outlets are NEMA 14-30 type, meaning they support peak 30 amps, 24 amps continuous, so limit your current draw to that, otherwise the breaker will flip on you, as these are usually heat-based devices. If it is NEMA 14-50, then your mobile connector should plug straight in (assuming you have that plug type in your kit, some cars did not come with that) and you can pull 40 amps.
Older style outlets, pre-1996, are often NEMA 10-30. See
NEMA connector - Wikipedia for what the plugs look like.
If after 30-minutes the dryer outlet or any plug seems really hot, turn the current down. At one place I go, I have to limit draw to 18 amps to stop getting a burning smell in the laundry.
Yes, I have done this at several places. But also don't fear the 110 volt outlet too. I charged from that at one place that was 60-miles from a supercharger, and just kept it plugged in all the time. and got to 100% by the time we left for the airport without having to top off to please the Turo rental man. Also, it is rare for there not to be a level-2 J-1772 charger in town somewhere. PlugShare lists public chargers of all types, so check the map for what is near your destination and there are even private EV owners willing to share their juice with you. Bring your j-1772 adaptor. Also check out CCS adaptors if there's a charger like that near your destination.
Concerning range anxiety, remember that if you are at high-elevation, your downhill cruise to the SC will use less power than the uphill climb, so you will need less kWh to get back to the lowlands.
