earthwormjim
BTW, I can only get the SSRs to open if I connect ground to "-" and 5V to "+". It does the same thing with a 9v battery, requiring that I connect "-" to "+" to open and light up. Any idea why that is?
Isn't that what you expect, active high? When you say open, do you mean allow current to flow through, or do you mean open switch, as in no power through?
There is an LED that is activated when you apply power across the + and -. That LED shines light on a photo-transistor. That phototransistor will then trigger the TRIAC, which allows AC current to flow into and out of the SSR. Since it's a TRIAC, it's going to be a zero cross trigger, meaning once turned on, it will stay on for at least 1 AC half cycle. TRIACs stay on as long as current is flowing through them, no matter what you do with the trigger terminal.
By the way, there is going to be a 1-2V drop across that SSR. So if you're pulling 32amps, that's 32-64 watts of power dissipation in the relay. You're going to need a much bigger heatsink, and possibly active cooling (fan).
I like those relays, I use them for inrush testing at work, they provide very clean switching, but I'm not so sure they can really handle continuous 32-40amp loads.
That's a neat meter you found, looks reasonably accurate too, good choice.
