That doesn’t work for me. When defrost is on warm (defrost icon is red), it is set to auto as you eluded. Fan blows at max. The fan speed controls are grayed out. Photo 1 below.
When the defrost is on cold (defrost icon is blue), the lowest fan speed you can select is medium. Photo 2 below.
However, if I turn off auto, the defrost icon turns off and air is no longer directed to the front glass. Photo 3 below.
The only manual option I see is to direct the air above using the icon on the left and set to 1. Not sure if that is the same as defrosting on low. Photo 4 below.
So the question stands - how do I turn on defrost mode and set the fan speed to low?
v11.1 (2022.44.30)
