Develop app with fre of charge api
Hello,
I would like to develop an app that communicates with my M3 without using charged APIs. I followed the instructions on the timdorr.com website. Step one is ok but I'm not getting the "set-cookie" and "_process" fields. The second step fails saying that i'm not authorized. Does anyone have any suggestions and/or can give me a sample program (in any language) that passes the authorization phase.
Thanks in advance
Timdorr doc first says to log in and it's that I do (but the answer is different from doc as I said). What you mean for auth token, is it doc authorization_code? If yes I should receive it in the second request, but it fails? Have you a different doc? thnks
Ah, they've uograded their authentication to full-on OAuth2 since the last time I checked. In steps one and two you obtain an authorization code and you use that code in step 3 to get the actual token that you need for all subsequent requests. You can read about OAuth2 authentication in general first to familiarize yourself with the principles.
