I jumped into a used car a little suddenly (instead of waiting for new order) so didn't get the wall charger for full 11 kW sorted. I'll get to that - requires a fair bit of destruction to get a cable conduit where it needs to be. In the meantime I'm charging from the garage. I'm in Europe so that's 16 A standard socket and I get 13 A charge rate. Was a bit confused by that at first but after reading a bit I believe it's the UMC doing a bit of nannying there.
So I'm thinking to improve this temporary situation a little. Garage supply is 32 A with a mini CU in the garage with breakers for sockets, lights and the car lift. So I could install a 16 A blue socket to get the full 16 A charging, or even a 20 or 25 A breaker to a 32 A blue socket for a bit more. Reluctant to draw the full 32 A sustained. Then just need to get the right adaptor for the UMC.
But what I'm scratching my head about is in my car or the app I can't choose more than 16 A in the charge limit. So how will I allow 20 or 25, or indeed the full shebang when I get the wall charger on 3-phase? Reading up a little I'm concerned this indicates my car charging system is broken! As far as I can tell there's no reason in theory I shouldn't be able to set 32 or even 48 A here when not connected to any charging equipment with a lower limit?
Am I right and is my car broken and needs to go in? Early 2022 M3 LR by the way.
