  • The final cut of TMC Podcast #34 is available now with topics timestamped. We covered Tesla's rollercoaster prices, Toyota pushing junk science, Mike's new Model 3, Optimizing track mode for snow driving, FSD V11 apparently coming by the end of this week, and more. You can watch and check out the chat replay on YouTube.
Differences in these LED sequential turn signal fog lights
I am thinking of replacing the dummy fog lights in my 2021 M3 SR+ with a sequential turn signal fog lights. The ones that have an amber turn signal but white colored running lights.
Whats the difference between these 4 that I've found? Unsure which one I should get for 2021 M3 SR+. Are all 4 the same product?
- Tesla Model 3 & Y LED Sequential Turn Signal (Fog Lights)
- Front Fog Lights Sequential Turn Signal Upgrade Kit For Model 3 2017-2022
- Model 3 SR (Standard Range) LED Sequential Fog Light Upgrade with Turn Signal Indicator (1 Pair)
- https://www.amazon.com/KeeForthewin-Daytime-Sequential-Clearance-accessories/dp/B08TX4G9X8/ with SR+ harness
Reactions: phaheem
Yep, all the aftermarket fog lights you’ve listed above are made by the same manufacturer and then redistributed/resold by many different retailers. Looks like you are aware that you’ll need the extra wiring harness since your particular vehicle did not come with functioning fog lights. Just make sure the kit you purchase is supplied with that extra wiring harness. Or, purchase it separately like you’ve shown above with the additional Amazon link.
I bought the one from Amazon but without the extra wiring harness, since my vehicle came with functioning fog lights.
Good luck and hope you can find good instructions on how to run/connect the extra wiring harness!
Reactions: phaheem and nyxynyx
Did you get this sorted and working? Looking to add these to my SR+.
tlr1000
1,053
780
Vancouver
The oem fog lights are purpose designed for fog situations. Although these are called "fog lights" do they actually emit a fog beam pattern or just random scattered led light for cosmetic purposes? To put it another way, for those with oem fog lights, will changing to these decrease the lighting performance for fog situations?
Reactions: phaheem
Hayden
1,552
847
Belgium
These are DRL with sequentiel turnsignals, no fog lights.
tlr1000
1,053
780
Vancouver
Thanks for clarifying. Guess that means those with factory fog lights would lose that functionality for the cosmetic change. The one thing that confused me was the fact that some instructions I've seen rely on oem fog light power for these units but guess that power source is now used for cosmetic lighting rather than fog lighting.
I bought them on Aliexpress.com with the harness incl.
Here Aftermarket fog lights you can read more.
It's a big job to install but not that hard.
If you have questions than i be happy to help.
Thanks Hayden. Look good and liking to get some, can you remember the seeker you got them from? Look at at RPMTesla as they deliver to UK but are a bit pricey.
Hayden
1,552
847
Belgium
Reactions: UNCLETYS
Did you hook up the blinker portion? If so, how does it affect the tesla light shows? Can you upload a video sample of a light show playing with these installed? That would be very helpful, thanks.
