Bump for update (<cough shroud!>)?
Hi Roentgen,
I have a few current prototypes which require you to align the top and bottom halves of the shroud. You will then need to use two included 5mm Allen screws to attach the two pieces. A little difficult to do as you will need to get to the bottom of the display. But it does not require you to disconnect the display.
I also drew up a new prototype which will just snap into place. This version will require the removal of the current shroud, disconnecting the display plug, removing the OEM shroud, and reconnecting the display plug.. They will however be more difficult to separate later. I am waiting for a shipment of metal clips to make this happen.
In the mean time, I did play with a few different screen/bracket angles as we have discussed. After driving with each versions, I do like the current version best.
Let me know which shroud you prefer.
CJ
