Sun's MY is back for a set of the new AlphaRex NOVA-Series LED Projector Headlights:
Before
After
Before
After
How is the ride quality with this setup as compared to KW coils?Tein EnduraPro Plus dampeners and H&R lowering Springs for this MY
Not really a valid comparison, as the KWs are a complete 3-way coilover system.How is the ride quality with this setup as compared to KW coils?
Thanks, Please update with your review when its all dialed in!Not really a valid comparison, as the KWs are a complete 3-way coilover system.
Overall the Tein/H&R is a bit softer than OEM, we haven't had enough time to play with all the adjustments to find the sweet spot yet.
PM sent!Hi Tom,
Can you DM me a price installed on this please?
Thank you
Are the rear camber arms something that would be required or this setup or would the Tein coilovers be sufficient without them? Looking to have a similar set up, not a super aggressive drop or anything. Thanks!TEIN Flex Z Coilovers and Redwood Rear Camber Arms for this Model Y LR. Dropping 42mm up front and 42mm rear in ride height to close that wheel gap.
Stock Ride Height
Driver Front: 693mm
Driver Rear: 697mm
Pass Front: 693mm
Pass Rear: 697mm
Flex Z Coilover Ride Height
Driver Front: 651mm
Driver Rear: 658mm
Pass Front: 651mm
Pass Rear: 657mm
TEIN - Flex Z Coilover Kit - Tesla Model Y
TEIN has released the FLEX Z Coilovers for the Tesla Model Y! Tein FLEX Z inherits all the features and quality of STREET FLEX but the adoption of the new platform allows its price to be set at a low range. FLEX Z, of course, maintains the long-favored "Made in Yokohama" quality. Considering the...europeanautosource.com
Redwood Motorsports - Spherical Bearing Adjustable Rear Camber & Toe Control Arms - Tesla Model 3/Model Y
Redwood Motorsports is proud to present our exclusive Adjustable Rear Camber and Toe Arms - featuring Aurora Bearings™ motorsports grade Teflon lined bearings. These adjustable control arms replace the non-adjustable factory arms, allowing you to dial in custom camber and toe settings to...europeanautosource.com
Before (Stock height)
Installation
TEIN Flex Z Coilovers & Redwood Camber Arms installed
Highly recommended with coilovers, as this allows to keep alignment in check.Are the rear camber arms something that would be required or this setup or would the Tein coilovers be sufficient without them? Looking to have a similar set up, not a super aggressive drop or anything. Thanks!
Depends on how aggressive you are looking to lower. For those wanting an agressive drop, rear camber arms are recommended to keep alignment specs in check. We carry everything in stock if needed.Is the rear toe arms is also necessary or rear camber arms is okay without the rear toe arms with the Tein Coilovers? how abou the front?
