Vendor eas | Southern California Tesla tuning source and daily showroom
Hard to beat Volks on MYP. Coming back for an Adro Full Carbon Aero Kit next!
What front lip is on this now?
Here's some pictures of the new Koni Red Special Active Struts.
I have a 2022 M3P and would love to do this BUT so frighten of, if anything went wrong with the suspension, It will not be covered by Tesla's warranty. Even if it was a Tesla part.
Am I wrong in this thinking???
ST and KW have been in business for over 25 years, with KW being exclusive partners with BMW's Motorsport division. They would not release a product that was not properly tested or unsafe, in fact - they are much better quality and performance much better than your OEM suspension components.
Granted we're not installing 4-way suspension systems on street-driven Teslas, but this technology does trickle down to all kits in the product line.
But bottom line is: If something goes wrong with any Tesla part in the suspension system, it will not be covered by Tesla, even if all that was installed was lowering springs, correct?
Impossible to give a blanket statement as every situation and SC is different. If you're worried about warranty, simply wait to mod until your warranty has lapsed.
Koni Yellows are officially inbound, should have them in a couple of days. Order now to reserve a set!
HPS
HPS Performance Products is a leading manufacturer of engineered joining solutions. HPS currently serves the aerospace, automotive, construction, marine, high performance racing vehicles, commercial truck and bus, agricultural and off highway vehicles, turbo diesel, off-road, truck, food and beverage, general manufacturing industries and water treatment industries. HPS Silicone Hoses also supplies many well-known international firms and our silicone hoses meet or exceed SAEJ20 standards. The ability for HPS to manufacture custom shaped, multiply silicone hoses make it ideal for a wide range of applications. The multiply carcass makes our hose ideal for coolant and turbocharged pressure applications while the fluoro silicone- lined hoses make it safe to be used with petroleum based fuel and oil.
HPS Performance Products continues to meet the original goals of quality products, competitive pricing, and personal, timely response to customers’ needs. Our expertise in silicone hoses allow us to deliver standard sizes silicone hoses with same day shipping; HPS highly skilled and knowledgeable staff, paired with state-of-the-art technology, ensures HPS’s continued success as a premier manufacturer in the industry.
HPS Aluminum Undertray Skid Plates, they're made here in the good 'ol USA and have Plates for both Front and Rear in black finish:
Features
  • Available for both Front and Rear locations for ultimate protection
  • Protect the life line of your Tesla from coolant lines to high voltage cables
  • Drive worry-free with a 2 year limited warranty included with each skid plate
  • Precision cut from 1/8" thick 5052 Aluminum
  • Stainless Steel Hardware is included
  • Direct bolt-on installation
  • Reduced drag coefficient compared to OEM
  • Made in the USA
ST Suspensions
For all those who want to influence more than just their ride height. ST XA Coilovers deliver the look you need through a wide range of height adjustment. With an extensively adjustable damper setup, you can precisely adjust the driving behavior of your car to achieve enhanced road control without a compromise in comfort.
EAS is an authorized KW & ST Suspensions dealer - ready to ship immediately or install at our 8000sq ft facility in Anaheim, CA.
XA - More than just lowering
Features
  • Front Lowering: 1.0" to 2.0"
  • Rear Lowering: 1.0" to 2.0"
  • 18 Distinct clicks of Adjustable Rebound Damping
  • Individual lowering within the tested adjustment range
  • Front and rear axle thread adjustment (when possible)
  • Galvanized coilover struts with additional coating for optimized corrosion protection
  • Complete solution with adjustable spring perch, multi-coated spring system and dynamic elastomer bump stops with dust protection
  • Powerful twin-tube dampers with high-quality components for maximum longevity
  • Backed by ST suspension's 5 Year Unlimited Mileage Warranty
Individually Height Adjustable
ST XA Coilover kits deliver precise adjustment to your ride height and look of your car. We manufacture the adjustable spring perch made of durable and friction-optimized polyamide composite material with a stainless steel insert. Thanks to the composite material corrosion is prevented between the strut and perch ensuring long lasting height adjustability while the stainless steel insert provides strength and confidence!
Control The Details
More control of the driving dynamics thanks to adjustable KW rebound technology. ST XA Coilovers come preset to our factory recommended damper settings, the same configuration we test them at on our KW shock dynos before they go into your box. The 18 distinct clicks of adjustable rebound damping allow you to refine the driving dynamics with a simple turn of the adjustment knob. Each kit includes a detailed damper setup manual making it easy to reset to our recommended setting at any time. Whether your preference is comfort, sportiness, or something in between; ST XA puts the finer details of the driving dynamics in your hands.
Closed Rebound Stage - Sporty, tight and maximized performance
Turning the adjustment knob to the right, you increase the rebound force and achieve tighter handling. High rebound forces (closed rebound) improve the handling response, this is especially noticeable on the front axle; the response is a direct and unadulterated sporty experience. This closed rebound stage is ideal if you enjoy spirited drives, long curved banks, canyon carving, and more.
Characteristics at a closed rebound stage:
  • More direct steering
  • Improved handling
  • Pitch and roll movements of body are greatly reduced
Opened Rebound Stage - Retained comfort with added sportiness
Turning the adjustment knob to the left your ST Coilover suspension will provide a much smoother ride and improved ride comfort compared to standard shocks and lowering springs. This is ideal when driving on uneven and rough roads by helping to absorb road frequencies. The opened rebound stage takes ride comfort to the next level.
Characteristics at opened rebound stage:
  • Increased rolling comfort
  • More driving comfort
Galvanized steel struts, low friction materials with layers of protection
Galvanized zinc coated steel struts optimize corrosion protection for long lasting use. We add a dust protection system to prevent unwanted dirt and particulate from coming in contact with the hardened chrome piston rod or getting into the valve packs. We reinforce the system with a multi-layered pressure resistant sealing package, mono block guide system and a low friction piston band which works inside the pressure resistant internal damper housing.
Unique Features
The high quality ST XTA Coilovers have numerous unique features that provide unparalleled value and a long lasting durability.
  • Composite Spring Perches
  • Two-Piece Racing Spring System
  • Dust Protection and Weather-Resistant
KW Quality – exclusively for ST suspensions
The ST suspensions coilovers benefit from our many years of experience in the development and production of suspension components for motorsport and the street. Each damper is hand assembled specifically for your order and put through rigorous quality control testing before being placed in your box for delivery.
Whiteline
For over 30 years, Whiteline has a worldwide reputation as a leading manufacturer of replacement, enhancement and performance suspension components that deliver significant gains in vehicle balance, steering precision, grip levels and outright driving performance.
Whiteline's boasts a worldwide reputation as a leading manufacturer of replacement, enhancement and performance suspension components that deliver significant gains in vehicle balance, steering precision, grip levels and outright driving performance. Consisting of adjustable sway bars, lowering springs, handling kits, chassis bracing, alignment products and chassis control bushing kits, Whiteline products provide automotive workshops, tuners, enthusiasts and racers with innovative solutions to suspension and handling problems while delivering proven performance & problem solving outcomes for many of the worlds vehicle platforms.
Whiteline products are developed up by a qualified and willing engineering group of dedicated enthusiasts who are trained in the company's products and philosophy. Using a range of sophisticated testing and data logging tools, we rely on comprehensive testing to maximize the product benefits and ensure that they work as a complete package tuned to give you the best handling outcome. Whiteline has the products and practical experience to maximize the potential of your vehicle whether it be a daily driver, street performance or motorsport vehicle and guarantees a quality, tested and tuned outcome using Whiteline products.
SPL Parts
From full racing to high performance street applications, SPL suspension products provide adjustability and increased performance for custom alignment needs. The highest quality construction and innovative features are the reasons why our products are not only chosen by the top race teams, but also by consumers demanding the best alignment products for their high performance street cars.
Powerflex
Powerflex has extensive knowledge and design experience in automotive suspension and chassis systems. These design skills have been combined with advanced polyurethane manufacturing techniques leading to the development of a wide range of high-performance automotive polyurethane components that are second to none in quality and performance.
AP Racing
AP Racing is the leading manufacturer of performance brake and clutch systems for road and race cars. The core product range includes clutches, calipers, discs, pads, master cylinders, pedal boxes and air jacks, as well as road and competition brake systems for motorcycles. AP Racing are leaders in performance braking solutions that are proven to perform in even the harshest, most demanding conditions on- and off-track.
N2itive
N2itive’s brand new ground breaking high pressure forged adjustable camber arms are finally almost here! N2itive has designed these control arms to give you the freedom to dial in the ideal alignment for track or on the street to address the common inner tire wear issues that the Tesla Model 3 and Y are known for. These are even more critical if you’re planning to install these on a lowered Tesla or a high mileage Tesla. Our adjustable camber arms will allow you to add or remove rear camber to your liking. Either for optimal track or street wheel alignment. These are a much improved direct drop-in replacement for the original Tesla rear camber arms and come preset to the length of the original non-adjustable arms.
All products are made with the highest quality materials and craftsmanship for years of endurance and come with an unmatched 6-year to lifetime warranty!
Torque Solution
Torque Solution manufactures and carries only the finest after market accessories for your Vehicle needs. If you are looking for great suspension products at the best price, then you have come to the right place.
Paragon Performance
Established in 2014, Paragon is dedicated in supplying high quality performance brake products for a wide range of motorsport, high performance, and sport driving applications. Our product range includes brake kits, rotors, brake pads, accessories, as well as other brake components. With extensive knowledge and background in motorsport products and services, we understand customers’ demand for street, track prepped and race vehicles.
Paragon products are precisely manufactured in a manufacturing plant with 26 years of experience in manufacturing and machining. Close attention is paid during development, testing, and design to ensure our products to perform well and safely under all conditions.
Paragon sponsored the brakes on two Team Honda Research West (THR-W) Civic Type R which competed and finished the enduro fourth and seventh in a highly competitive class (Class E0) of the famous 25 Hours of Thunderhill endurance race at Thunderhill Raceway Park. Close and ongoing cooperation with race teams including THR-W give us a distinct advantage by providing real-world data and professional product evaluation. With the use of advanced R&D technologies including CAD and 3D modelling, we strive to provide our customers with the best performance brake products.
Brada Wheels
Brada Wheels continue to be dedicated to producing not only wheels but also a lifestyle that reflects a passion for creativity and a desire for delivering the finest wheels. Performance and longevity is the hallmark of a great wheel. That is why we place a heavy emphasis on precision designing, precise engineering, and expert craftsmanship. Aiming to achieve the highest quality wheels in its class.
