Error in Tesla API
Discussion in 'Technical' started by ronaldderksen, Aug 30, 2018.
  1. ronaldderksen
    ronaldderksen Member
    Netherlands
    Hi,
    Today I noticed that when I use the unofficial tesla API. I get a response like this on vehicle commands:
    <html><head></head><body><p>Our servers are waiting for a supercharger spot..</p></body></html>
    The same call worked yesterday. Doe anybody know what this message means?
    Vehicle state commands are still working.
    The original Tesla app is still working correct.
    What I also tried was using:
    Tesla Model S JSON API · Apiary
    filled in my vehicle id and bearer token and I get above response. When I use the 'Mock server' I get the correct response
  2. morder
    morder Member
    us
    I ran into this issue as well and I added two new headers:
    User-Agent: Mozilla/5.0 (Linux; Android 9.0.0; VS985 4G Build/LRX21Y; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/58.0.3029.83 Mobile Safari/537.36
    X-Tesla-User-Agent: TeslaApp/3.4.4-350/fad4a582e/android/9.0.0
    These work and are based on the latest app i've installed. But I'm pretty sure the x-tesla-user-agent could be anything.
    • Helpful x 2
  3. ronaldderksen
    Netherlands
    Thank you. I needed to add both headers. It is working again.
    Ronald
  4. ronaldderksen
    Netherlands
    Just curious. How did you find these headers? Traffic from app to tesla api is encrypted via tls. On iPhone you cannot place a 'proxy' in the middle because certificates need to be valid.
    Ronald
  5. morder
    morder Member
    us
    I decompiled the APK for android and checked all the outgoing headers and then followed the code to see what their values were. my first thought was that the client keys changed but they're still the same.
  6. Mexfgzorro
    Mexfgzorro New Member
    mexico
    problems with vba code help
  7. morder
    morder Member
    us
    I don't know VBA but you don't give us much to go on.
  8. markb1
    markb1 Active Member
    San Diego, CA
    That's weird. The API is still working fine for me, and I haven't added those headers. I'm am using a very old client ID, though, so maybe that makes a difference.
  9. ronaldderksen
    Netherlands
    Thanks morder,
    I am going for a different approach to get these headers, for future changes. I will try to run a proxy and create signed certificates with my own CA (for the tesla api url). And via DNS redirect traffic to my proxy. I then only need to install my own CA on my own phone. If this works I can log all headers easily.
    Ronald
  10. Mexfgzorro
    mexico
    My problem,
    when put header
    it's wrong
  11. josephyi
    josephyi New Member
    Fullerton, CA
    In my case, I simply had to add 'user-agent' header to my node client with an arbitrary value. Strangely, postman, curl, ruby, etc. all worked, but there's something weird about node. Anyway, no time to figure it out, here's some copy pasta that you can try
    Code:
    var http = require("https");
    var options = {
      "method": "GET",
      "hostname": "owner-api.teslamotors.com",
      "port": null,
      "path": "/api/1/vehicles",
      "headers": {
        "authorization": "Bearer YOUR_TOKEN_HERE",
        'user-agent': '007'
    var req = http.request(options, function (res) {
      var chunks = [];
      res.on("data", function (chunk) {
        chunks.push(chunk);
      res.on("end", function () {
        var body = Buffer.concat(chunks);
        console.log(body.toString());
    req.end();
  12. JagCesar
    JagCesar New Member
    Sweden
    Thanks for sharing this guys. I was really scratching my head, I thought my code had somehow changed by itself
  13. tpoz
    tpoz Member
    Portland, OR
    If you have decompiled the code, is it possible to figure out the API calls for the summon feature? It would be great to document those.
  14. morder
    morder Member
    us
  15. Jonas_man
    Jonas_man Member
    Helsinki
    Hey guys while testing my swift lib i noticed that i dont need to add any header besides the content-type. POST and GET works just fine
  16. Allante
    Allante Member
    Greenville, SC
    Does anyone know what happened to the Tim Dorr API page where you can enter code directly into the console view? I know that it has moved to a new site, but it no longer enables you to type directly into the console.
    How can I do this now?
