That last cone is past the apex of the corner it's hard to set on a wide angle lens. It's also kind of deceiving because the long straight is an actual runway and that paved area to the right is a run off area. That last cone is the outside of the track for the corner. Also that back section isn't really straight there are a couple of slight bends you can straighten it out though. There is also a wall to consider coming onto the straight. You may be able to get a few more mph bit if you mess it up the consequences are pretty major. The way most people try to go through there is stay wide and fight the urge to apex at the curbing, then turn in and apex at the corner of the straight then accelerate and let the car work towards the outside as you start onto the straight.Has anyone tried going deep and wide on the end of the back stretch so that you almost hit the outside of the apex cone with the right side of the car and then make 1 sweeping turn hitting the inside apex at exit.
Seems like that would give you more time on the long back stretch and more straight angle out of the corner for the next straight.
