I just had my MR3 serviced at the Torrance, CA service center due to the following:
For number 1, see my pictures. The longer rubber stop is underneath the car's rear trunk. The one added by the service center underneath my front trunk hood is the shorter one. The shorter one doesn't have a compression mechanism, so it's fixed. I think the front trunk hood should have the same one as the rear trunk. Can you guys check your Model 3's front trunk hood rubber stops?
- Missing front trunk rubber stops - FIXED (I think, see my comment below)
- Interior trim above rear right-side passenger area mis-aligned - FIXED
- Rattle when driving 70 MPH or higher coming from front driver-side ventilation area - COULD NOT REPRODUCE DURING TEST DRIVE WITH TECH (of course)
- Loose plastic hinge over for front trunk hood - FIXED
- Side mirrors triangle trim sticking out - FIXED, BUT STICKING OUT AGAIN
- Doors having to be slammed to close - FIXED FOR 3 out of 4 DOORS
