I had the complete rear window replaced a couple of months ago after the cracked glass issue that affected a number of August 2019 Model 3 deliveries. That time there was a clear crack in the glass and the job was done no questions asked and under warranty.
I've used the demister very little since then but had cause to the other day - it wasn't a full mist up job but a light covering of raindrops where application of the heater can usually help shift it. However no joy - it didn't look like the heating element was on at all.
I have an inkling that the element/fuse has gone again although this time there is no sign of a crack in the glass or broken element.
Ideally I need a full mist up to test with but I'm getting a bit long in the tooth to suggest that the missus comes out to help with that . I don't have an electrical tester so is there any other way of working out if the element is working or not please?
Cheers
Cheers
