2015 MS 70D with 135k miles
The car won't shift into park! I can select Reverse, Neutral or Drive normally. I can engage the parking brake. Even exiting the vehicle does not engage the parking brake.
In fact, when I exit the vehicle with the car in a gear other than Park (Neutral with parking brake applied) the car provides the typical prompt "Car automatically shifted to park to prevent rollaway...". This is the message you would typically see if you forgot to shift to park. However, the selected gear does not actually change.
The parking brake in the menu is selectable normally and works. Apparently if the car is not in Park I can't even turn it off in the Safety menu (Power Off is greyed out).
I tried a 10s reset with both volume switches. I'll look at other software reset options also.
One additional highlight... my Toddlers love to pretend to drive my car. They mess with the steering wheel and gear selector all the time. They haven't done so in a few days, but wear and tear may be higher than normal because of that.
