I'm the lucky one that gets to maintain all my family's vehicles, and apparently my sister's 2013 MS P85 RWD decided it was feeling neglected. There are currently SEVENTEEN active alerts in it, the last time it moved, it locked her out of the vehicle b/c it thinks it is in drive (or neutral) and won't put itself to sleep. It DID eventually time out on her and go back to sleep / park mode / open the door handles after the key was away from the vehicle for about 20 minutes. This was about 5 days ago.
I get to it today, and the parking brake is now stuck ON. While it will go into drive and attempt to move, the brake is doing a VERY good job of holding firm. But it also refused on me to go back to "park" mode, and even with the key away from the vehicle for hours, still was sitting there in neutral with the doors firmly locked. (I left the window open)
ALL of these errors came on at the same time as the first error with the parking brake, but I am at a loss as to why some of them would be connected to the brake. I'm ALSO quite perplexed why so many modules are erroring as "MIA" or unavailable. Where do I start the diagnostics?
GTW_W025_easMIA - It wants service (duh, it's broken!)
GTW_W104_ocsMIA - Front pass airbag always on, unable to detect occupants
GTW_W105_rcmMIA
GTW_W037_espMIA - ABS disabled
GTW_W036_epasMIA - Steering assist reduced (try non existent! It is completely off)
PM_w016_cruiseMIA - Pedal monitor warning: Cruise Control CAN node is missing
PM_w017_brakeMIA - Pedal monitor warning: Parking Brake CAN node is missing
DI_w110_brakeMIA - Drive Inverter Warning: Parking Brake CAN node is MIA
DI_w109_cruiseMIA - Drive Inverter Warning: Cruise Control CAN node is MIA
DI_w091_espMIA - Drive Inverter Warning: Traction Control CAN node is MIA
DI_w089_shifterMIA - Drive Inverter Warning: Gear Shifter CAN node is MIA
GTW_W099_epbmMIA - Parking brake requires service Vehicle may be free rolling (Nope, it's locked to the ground like a Panzer)
PM_w015_shifterMIA - Pedal monitor warning: Gear Shifter CAN node is missing
PM_w009_espMIA - Pedal monitor warning: ABS CAN node is missing
GTW_w027_epbMIA - Parking brake requires service Vehicle may be free rolling
MCU_u005_FrunkOpen - This one is legit, it actually WAS open. All good here.
THC_d0010_compressor - Cabin Climate Control requires service (Don't know why, the climate seems to be working perfectly?)
I have pulled the 12v battery on the theory that this is too many glitches all at once to be much other than a power problem.... AND I don't know how old that battery is. If it isn't this.... I'm stumped. Thoughts? I gather that the parking brake motor probably needs replacement but what about the rest of this, why would ALL these modules suddenly be freaking out together?
GTW_W105_rcmMIA
