Based in Germany I am new to the "Tesla World". I took delivery of the M3 last week.
I guess with first M3s coming to Germany only last month, there is limited high speed handling experience with the car on "normal roads". Nevertheless, I would like to find out if anyone has had the same problem as me.
Yesterday I was driving at max speed 233kmh for an extended stretch (German Autobahn), the handling through long radius bends and slight undulations was very firm and reassuring. The M3s high speed handling very positively surprised me and is absolutely up there with a high end Audi/BMWs etc (which are made for high speed and the M3 I guess isnt). So far so good.
Later I was travelling at about 200kmh through another long radius bend (without undulations) and had to slow down due to traffic. As I touched the brakes at roughly 50% max brake power, the car suddendly got completely unsettled, ABS/ESP on all 4 wheels set off one after the other trying to stabilize the car only making it worse. The car all of a sudden felt like riding on soap! This ABS/ESP situation lasted for - what felt a few seconds - it was probably 2s? This is not a speed at whicih you want to crash out! Shocked of the experience I then reduced speed and a similar situation happened a few minutes later at around 160kmh (Darwin Award worthy?). For the record, I am stating below the conditions at the time.
After this incidence my confidence in the handling plummeted, as I don't know what awaits me next! Most disconcerning is that the car otherwise handles and brakes (in a straight line, even from high speed at 100% brake power) fine, so it would appear to be an electronic malfunction only under certain conditions.
I can only warn you not to "try this at home" as it was very seriously dangerous, but I would be appreciative of any advice or experience any of you may have had.
Car: Model 3 AWD LR 19"
Payload: only 70kg driver
Software: 2019.8.3 da116a6
Temperature: 14 degC
Road surface: Concrete
Dampness: Dry (warm afternoon)
Tyres: "summer tyres"
Tyre pressure: 2.9bar
Light: daylight
Road: Germany, A20 between Lübeck and Bad Segeberg, left hand curve near Mönkhagen travelling on left lane.
Light: daylight
