Hissing sound when any heat/ cold is on
Had anyone popped out the dashboard before? Whenever I put the heating/ or aircon my 2028 model s creates a hiss noise until I turn it off.
I’m assuming it’s a hole somewhere in the piping just behind the dashboard that maybe I could tape up. Probably wishful thinking or maybe it’s a loose bracket I can tighten up maybe (?)
No idea, is it possible to investigate this? Ie look behind the dashboard? Had a search but couldn’t see anything obvious.
Thanks in advance
So I tried this (see pic), waited for 4+ minutes using these settings and the air in the car wasn’t cold. It was more like a low temperature setting as opposed to actual air con being on.
Noticed there was no hiss tho when I had this running.
Yep, most likely need refill, due to a small leak. Of course, something else could be wrong, but most likely what I wrote. :)
The sound is there only if the compressor still runs, with barely enough refrigerant.
Thanks in advance
Have you checked for snakes?
