On modern tires, small changes in tire pressure (<5 psi) will have minimal effect on tire wear. Higher pressure will increase effective dampening rate, and your ride will feel stiffer. Your range may (or may not) receive a minor upgrade by bumping tire pressures from the recommended 42 psi to 47 psi. Ride was much worse, so I went back down to 42, then toyed with 37 psi. Handling got noticeably worse, so I've stayed around OEM recommended 42 psi on both summer and winter tires.
All my wore out perfectly evenly. On OEM suspension.
Now that I've upgraded to Ohlins S&T coil-overs, the date will need to be gathered from scratch.
Small changes in tire pressure (< 1 psi) can and do have meaningful impact on handling on track, but most consumer tire pressure gauges and not accurate enough to measure those. Track pressure have more to do with tires construction, sidewall flex, temperature management, driving style, track layout, and how fast you are pushing the car. Typically, you start with way colder starting pressure (e.g.: ~25 psi), and optimize to hit desired hot pressure values (e.g.: 38 psi). Yes, tires heat up that much. It's an entirely different ball game.
That would be net toe OUT, which is highly unlikely to go unnoticed as the car will be unstable and dart-y going straight.
Excessive toe IN would have the opposite effect, wearing out the outside of the tires. This one can go unnoticed for a long time, since there is no adverse effect on handling for regular folks.
Significantly higher than stock negative camber (above -3.0 degrees) will absolutely accelerate inner tire wear. But it will even out overall tire wear after a few track days. YMMV.
Tire pressures are all about shaping tire contact patch.
While I could run lower tire pressures with wider tires, running much lower will start distorting the sidewall and elongating the contact patch. That will not be optimal for handling. But again, it can be done.
And the effect will be observed in ride harshness way before you get to observe any meaningful tire wear changes. In my case, going with appreciably stiffer and significantly better handling Ohlins, I clearly value handling over comfort. So I'm good with factory pressures, until such a time that I get data to tell me that I can optimizer traction with a different setting.
YMMV,
a
