Follow up to First tire rotation at ~6,500 miles .
Did the third tire rotation at ~19,000 miles (second one done at ~12,500 miles).
I used a large scissor jack on the front jack puck to raise the car slightly so that the hydraulic jack I have could go under the rear jack puck. Leaving the car on two jacks while swapping the tires on one side is not ideal compared to getting all four corners on jack stands and doing a cross rotation, but the main difference in wear seems to be between front and rear (rear wears more quickly, since the RWD model that I have uses the rear wheels for all acceleration and regenerative braking).
I also got a deep drive 21mm socket and a 250 ft-lb torque wrench to make things easier.
The original Michelin Primacy MXM4 T1 tires started with 8/32". Before the third tire rotation, the rear tires had 5/32", and the front tires had 6/32". At this rate of wear, it is likely that the tires will last 43,000 to 50,000 miles to the 2/32" wear bars / legal minimum, although it is likely that they will be below 4/32" at around 38,000 to 40,000 miles when a rainy season starts (I usually replace tires if they are below 4/32" when the rainy season starts). Obviously, your tire mileage may vary.
