As @zanary stated it could do this based on Cost Savings mode but it should not dip below your reserve.I'm confused to why the GW is exporting 50% of my solar production when my PW is below the back-up threshold I have set (50%). Shouldn't all solar go to the PW, at least until the backup threshold is met?
I'm in self-powered myself. I'll try toggling around the settings and see if I can force something better.
Show us the intraday chart with all 4 targets selected so we can see the power flows over time. I may not be understanding your situation correctly, but it's possible if you have two solar inverters that the Powerwall is only measuring one and the production from the other one is going to the grid.I'm confused to why the GW is exporting 50% of my solar production when my PW is below the back-up threshold I have set (50%). Shouldn't all solar go to the PW, at least until the backup threshold is met?
The Home quantity should never go to zero. That means that the system is misconfigured somehow. Show a chart like this one by pressing the charting icon at the upper right of the Power Flow screen.Here's what it looks like. Home usage appears to go to zero when solar comes up (it should be around 0.4kW) and it starts exporting around 40% to grid rather than PW.
I'm on a single inverter system.
View attachment 520034 View attachment 520035
Thanks - they moved something around remotely before but I guess the installation made more than one error.Call Tesla Energy Support. You system is mis-configured. Hopefully they can change it remotely. However, if the Current Transformers are not placed correctly, the install team may need to come back out to fix it.
But, they must bilk you someplace else.Thanks for the info, both of you. We don’t use tiered pricing here in Virginia (another complication of California installs!).
Ha! Mostly that it takes forever to get approved for a certain amount of panels and it’s based on past usage. I’ve never gone back to recalculate for the EVs added after the fact so we are underproducing unfortunately. Could add a lot more solar panels and not be at our max of 102%.But, they must bilk you someplace else.
