HVAC Fan Noise Above Setting 7
Have a loud buzzing / humming sound coming from the HVAC fan at speed setting at 7 and above. Makes the entire car vibrate.
I just noticed it today of course after the warranty has just run out at 60,500 miles. I typically don’t turn the fan that high so I never experienced that sound before. Could have been there for years.
Anyone else share this issue?
2018 M3LR
Having this same issue but whenever the AC in general turns on. Gets liuder the higher you turn up the AC. Quiets down some when you turn of the rear. Also noticed only sounds when the actual AC mode is on and no sound when fan only is running. Side note: left fender camera also not working and both occured after previous update. Had service resend update still no fix. Today downloaded newest update but still same issue.
