Norbert
TSLA will win
Revealed: Elon Musk Explains the Hyperloop, the Solar-Powered High-Speed Future of Inter-City Transportation - Businessweek
Well, while of course inspired by Elon , I did consider "low pressure" at the beginning of this thread: (though of course wrong about the high pressure behind the vehicle)
And I did anticipate the air cushion: (I think only based on Elon's hint that it has things in common with a concord )
Now Musk argues that the Hyperloop represents a type of middle ground that other people have yet to consider. Instead of being a complete vacuum or running at normal conditions, the Hyperloop tubes would be under low pressure. “I think a lot of people tended to gravitate to one idea or the other as opposed to thinking about lower pressure,” Musk says. “I have never seen that idea anywhere.”
This Hyperloop thing kept me thinking. I don't know if this is a good idea, but at least it's an idea. Somewhat based on Elon's description of high altitude jets / fans operating at low air pressure:
So not a vacuum tunnel, but a somewhat air-tight tunnel for the pods (or ideally plexiglas tube above ground or below water in the Pacific, or whatever). One for each direction of course. And two air pipes along them, one with high air pressure, one with low pressure / vacuum, and every 100 ft or so, remotely controlled valves that connect the pipes with the tunnel. Then, when a pod is traveling in the tunnel, the valves for the low-pressure/vacuum pipe open ahead of the pod, and the high pressure valves open behind the pod. So the pod itself has no motor or anything, but is driven by the high pressure behind it, and the low pressure in front of it (which also decreases the aerodynamic resistance). Probably won't work because it's too inefficient (or impossible) to create a large enough pressure difference in the tunnel, but maybe it was an entertaining thought...
Or is that actually how the office pressure communication works...?
If the railgun were used like a catapult to make the hyperloop-vehicle fly from SF to LA, then it would really be difficult to see how it couldn't crash.
So, I'm wondering whether it would fly over ground with an air cushion (and no or only very small wings), and the two electric wires would go all the way from SF to LA (as for electric buses), yet not carry the weight of the vehicle (only perhaps be a guidance for the steering mechanism).
