Industrial Electric Vehicles
Discussion in 'Electric Vehicles' started by vfx, Jun 17, 2008.
  1. vfx
    vfx Well-Known Member
    CA CA
    A new thread for the massive Industrial Electric Vehicle industry that surrounds us but we may not even know it.
    Every time I go to Burbank airport I take a picture of the charging stations that are just outside the window where you stand in line at the gate.
    The cables are huge (perhaps 2 to 3 inches dia They hang on big metal "T" framework and when you pull on the massive cord it is tied to a rope that counterbalences with weights or a spring (a big version of a ceiling cord reel) to assist managing them to the vehicles. (Can you say 400amp quick charge?)
    These are big luggage vehicles (I mean big) and some other unidentified Airport "trucks"
    When I see them I am always reminded there is an Electric Vehicle industry that supports us in the background.
    Forklifts, milk floats, golf carts, are just some of a billion dollar industry (Ok, I made that # up but I believe it's actually a small #) There are industry magazines, websites and organizations that support Industrial Electric vehicles.
    Some of these genes will make their way "bottom up" into our future EVs. So, to pay tribute to our electro-embrionic roots here is an initial offering to get the ball rolling.
    http://blog.seattlepi.nwsource.com/electricvehicleguide/archives/141183.asp
    And there is this:
    http://www.sae.org/ohmag/techinnovations/06-2008/11-16-4-8.pdf
  2. vfx
    CA CA
  3. vfx
    CA CA
    Balqon - Advanced Transportation Solution
    The E20
    Also check out the M150
  4. domenick
    domenick Nerd
    Florida
    Balqon is launching its Class 7 Mule150. This is the kind of truck I drive every night. If only it had 300 mile range.
  5. Serge
    Serge Member
    Queens, NY
    Interesting evolution of their lower-speed, but higher capacity Nautilius trucks. Looks like a perfect delivery truck for cities.
    I am curious about a couple of things.
    First, the Li-Ion pack has a whopping capacity of 280 kWh, but claimed range is "only" 150 miles unloaded and 90 fully-loaded. I quoted 'only', because ~100 mile working range is probably more than sufficient for intended applications. It's just that 2.8 kWh/mile consumption is surprising (roughly 10x more than the Roadster). Perhaps a much smaller portion of the pack is used?
    Second, a 6-speed transmission is utilized. With max torque available at low RPM, which is a critical performance characteristic for freight-hauling vehicles, and relatively low top speed (50 mph) this again is a bit of a surprise. Maybe their "rugged" motor is only capable of lower RPM range. Do they need to talk to Tesla about motor tech :cool: ?
    On the other hand, charging tech is top-notch:
  6. TEG
    TEG TMC Moderator
    Lets say a gas truck gets 6MPG, but an Elise gets 30MPG.
    30MPG/6MPG=factor of 5
    2800Wh/mile / 280Wh/mile = factor of 10
    It does seem like they should be able to do better.
    Perhaps they haven't efficiency optimized as much as Tesla?
    Low rolling resistance tires? Low resistance wheel bearings? Low resistance alignment? Roll-back seal brake calipers? Their truck body doesn't look like it has spent any meaningful time in a wind tunnel.
  7. dpeilow
    dpeilow Moderator
    Winchester, UK
    Smith has had the Newton truck for a while now, which has a 12t gross weight with 7.3t payload.
    It has a 150 mile range from a 130kWh pack.
    Not sure what ABG are getting excited about really.
  8. vfx
    CA CA
  9. dpeilow
    dpeilow Moderator
    Winchester, UK
    250kWh pack. Wow.
    It's funny, it was only last week that I got a face full of fumes from one and thought it was the obvious next target for electrification.
  10. Adm
    Adm Active Member
    The Netherlands
    #10 Adm, Dec 28, 2010
    This is one of two buses driving in Rotterdam (Netherlands). They have the electric motors in the rear wheels. They have a 100kWh Li ion Phosphate battery with expected 2000 charge cycles (they expect 6 years of operation). Charging can be done in 4/5 hours. The bus also has a 50 kW generator on board to be used if the juice runs out (after about 4 hours of operation).
    GPS determines where the bus operates fully electric (city center) and where the batteries can be recharged.
    I'm sure I forgot to mention important facts, but I'm not an engineer...
    The website is in Dutch...
    http://www.ebusz.nl/
  11. mattjs33
    mattjs33 Member
    Antioch, Illinois, U.S.A.
    Also -- not really the same, I guess you would consider them a hybrid, but all "diesel" locomotives are actually diesel/electric. Now there's some torque!
