RaeW
Sure, it CAN work fine. But you can't tell us that there isn't a possibility that the perfect storm of the car forgetting the setting and a faulty breaker couldn't occur and cause a fire. Doesn't seem like it's worth saving a few bucks. Anyway, the main thing is that it would be irresponsible to recommend it to newbies asking for guidance here, even if it works for you.
I don't recommend anything. Perhaps you did not see my post to whoster69 who raised this issue to begin with. Here it is as previously posted:
I did this exact same thing, but there are cautions.
My electric dryer outlet, while dedicated, is fed from the panel to a junction box in the basement rafters. This is because the genius electrician who did original construction knew I had a gas dryer and tried to save a few bucks by running a line in the basement only (dryer is above box on first floor). I made him complete the job before we moved in. Several years ago I disconnected the dryer outlet at the junction box and ran the line to the garage (luckily the electrician had used a deep junction box). I have been using this 30 amp circuit for charging my MS (at 24 amps) since 2015.
NOTE THE REQUIREMENTS:
Check your local building code.
You must use the proper gauge wire for the distance (your dryer line may or may not meet this requirement).
You must use the proper outlet (don't use the dryer outlet).
You can only charge at 80% of breaker rating (24 amps on a 30 amp breaker).
