Max stock camber is maybe 0.5°. There are no useful adjustments for this on the Model 3. All you can do is push the upper control arm mounts in as far as possible in the slack in the bolt holes, and stock camber is near zero. It's the biggest limitation of the platform for stock performance. The rear has zero adjustment.
The Model 3 doesn't need sway bars until you are really pushing other mods due to the very low CG. If you're willing to change sway bars, that's already a suspension mod. Do the front upper control arms instead, and get some camber, which will increase performance and reduce tire wear. Running half a degree on the track will tear up your front tires. The FUCAs are a quick install/removal with no permanent changes. I've brought my car in for warranty stuff with them with zero comments.
If you're looking for a track setup, I would run the stock wheels/tires on the street and throw your 200TW's on for the track. Why would you want to wear out those expensive tires on the street anyway? A set of tires fits into the Model 3 easily so you can even swap at the track.
10/10ths on a track is gonna require brake system changes. The stock non-P brakes are not up to heavy use even with updated pads. This is still a heavy ~300 HP car. The E-LSD can really beat up the brakes as well if you are driving up against the nannies which you can't disable.
FYI, the warranty specifically excludes any track use, so you're risking the warranty the instant you take it to the track.
Plan on 300-330 wh/mi energy use on the highway with 200TW 275's unless you want to drive at 55 MPH. That would put an SR at 150-165 miles range from full to empty with the 50kWh battery. I only get about 200 useful miles on my 72kWh battery and that's with 400TW 265's.
If all you care about is lap times and you're an experienced track driver, I bet the car would be faster with a plug-in box that lets you defeat the nannies than any physical suspension mods, or even monster sticky tires. The stability system is pretty intrusive when not in track mode. Mountain Pass goes as far as to call "the Model 3 being essentially useless on the racetrack" without stability defeated.
Previous discussions:
Hi, I am deep down the rabbit hole about the decision between LR and P (as soooo many people here too). It is currently 5k difference here in Europe, but I am not sure if it is worth it and if I need it even for trackdays... The question is: Will the LR survive 2-3 trackdays a year? I am a...
teslamotorsclub.com
