SSonnentag 埃隆•馬斯克 Apr 11, 2017 1,973 2,687 Arizona Mar 26, 2020 #1 Mar 26, 2020 #1 My battery has two lumps on it, so I had them tested. One came back negative, the other positive. I hope it's not terminal. Reactions: Akikiki, MXLRplus, linux-works and 5 others
Puddles Member Jun 2, 2017 730 938 Fresno, CA Mar 26, 2020 #2 Mar 26, 2020 #2 I'll tell the jokes around here
cucubits Active Member May 17, 2019 1,774 1,855 TX Mar 26, 2020 #3 Mar 26, 2020 #3 SSonnentag said: My battery has two lumps on it, so I had them tested. One came back negative, the other positive. I hope it's not terminal. Click to expand... Reactions: PhilDavid
SSonnentag 埃隆•馬斯克 Apr 11, 2017 1,973 2,687 Arizona Mar 26, 2020 #4 Mar 26, 2020 #4 Reactions: MXLRplus, linux-works, vbaker and 1 other person
vbaker Member May 19, 2018 146 108 Ohio Mar 26, 2020 #5 Mar 26, 2020 #5 SSonnentag said: View attachment 526099 Click to expand... Watt are you trying do do here? It seems a little re-volt-ing.
vbaker Member May 19, 2018 146 108 Ohio Mar 26, 2020 #6 Mar 26, 2020 #6 vbaker said: Watt are you trying do do here? It seems a little re-volt-ing. Click to expand... Ohm Y gone, that is not even funny.
vbaker Member May 19, 2018 146 108 Ohio Mar 26, 2020 #7 Mar 26, 2020 #7 vbaker said: Watt are you trying do do here? It seems a little re-volt-ing. Click to expand... But I am amped up to see what you post next!
vbaker Member May 19, 2018 146 108 Ohio Mar 26, 2020 #8 Mar 26, 2020 #8 vbaker said: But I am amped up to see what you post next! Click to expand... I bet you could talk to yourself all day.
vbaker Member May 19, 2018 146 108 Ohio Mar 26, 2020 #9 Mar 26, 2020 #9 vbaker said: I bet you could talk to yourself all day. Click to expand... Yes, I have been known to drum up a conversation with a doorknob. I've had some good ones.
vbaker Member May 19, 2018 146 108 Ohio Mar 26, 2020 #10 Mar 26, 2020 #10 vbaker said: Watt are you trying do do here? It seems a little re-volt-ing. Click to expand... I am current-ly not impressed with this thread. Maybe it is because of one person dominating the posts...
linux-works Active Member Dec 23, 2019 2,327 4,499 mtn view, ca Mar 26, 2020 #11 Mar 26, 2020 #11 you guys.... you guys are such a bunch of Kirchhoffs !
vbaker Member May 19, 2018 146 108 Ohio Mar 26, 2020 #12 Mar 26, 2020 #12 linux-works said: you guys.... you guys are such a bunch of Kirchhoffs ! Click to expand... Zero impact. Reactions: linux-works
vbaker Member May 19, 2018 146 108 Ohio Mar 26, 2020 #13 Mar 26, 2020 #13 vbaker said: Zero impact. Click to expand... Oh come on! With a little outside influence this could become a positive thing. Reactions: linux-works
linux-works Active Member Dec 23, 2019 2,327 4,499 mtn view, ca Mar 26, 2020 #14 Mar 26, 2020 #14 vbaker said: Zero impact. Click to expand... "no[de] comment"
vbaker Member May 19, 2018 146 108 Ohio Mar 26, 2020 #15 Mar 26, 2020 #15 linux-works said: "no[de] comment" Click to expand... Spice-y! Reactions: linux-works
vbaker Member May 19, 2018 146 108 Ohio Mar 28, 2020 #16 Mar 28, 2020 #16 Jokes. My ICE is better than your EV... because.
