You probably soaked your front splash shield.... check that if still 'fresh'.
Best way to do this is actually from below.
Remove the filters, close the lid, lift car, remove splash shield, locate drain hole where you would expect a firewall on a normal car (and condensate leaking directly onto a high voltage line below it).
Feed a tube connected to your Koolit or foaming agent of choice in and up the drain tube... spray away.
Then after 15 minutes, put fan on high and let the fluid leak out as you watch it do so... should be at least a cup full.
