And if you look through the footage carefully enough, I'm sure you will see the face of Christ/Musk/Trump/Whoever in the fireball; appearing there as a deep, powerful and timely reminder that the human brain is hard-wired to see faces.
This is dodging the obvious question. What is it that appears to be streaking across the video frame coincident with the start of the explosion? Someone has posted another Youtube video slowed down to 1/250.
At :28 in the clip the black spec enters frame from the right. At :32 its much closer - appears to be moving very fast. At :33 it is closer still and since the previous frame the explosion has begun. At :37 the object seems to be passing over the rocket. At :39 it is nearly out the frame.
Next, what's the most likely cause of what the video shows? Something small moving across the camera's field at just
the right vertical height, but between the video cam and the rocket, very close to the camera.
I don't buy it is an insect very close to the camera for same reason as Pikachu88. Seems too straight and no variation in apparent height frame to frame. With video clip slowed to 1/250 I think we'd seem some.
A bat or bird 100+ feet from the camera is another story. Both can fly fast and straight. If the video cam's internal resolution was high enough, enlarging the image greatly might show some features of the black object that would show wings or wing motion. I think my video engineer friend would agree that the resolution the video cam stored is likely far higher than that of a uploaded clip. So only someone with access to the memory card would be able to enlarge as much as necessary.
The other option for determining how close object was to camera is to look at video taken by a second or third video cam located 30 to 60 + degrees from the camera taking this video. If no black spec on those videos then case closed.
With 3,000 separate channels of telemetry built into the Falcon 9, I would think they must have been recording more than one video of the rocket static firing, just in case this type of anomoly did occur.
If one or more do exist, why not make those public? Has anyone seen yet any posting from SpaceX on what's seen in the video?
