Disable any third party logging apps (Teslafi, etc.).
Charge it up to a high SoC before you drop it off.
Resist the urge to log into the app every 2 hours to check SoC and obsess about vampire drain (keeps the car from sleeping).
Don’t worry.
90% would be fine. That's how most charge on a daily basis.
Daily is one thing. Leaving it that high for weeks with out using it, isn’t great for the battery.
If it was plugged in most would recommend 70%.
The whole point is it’s going to not be plugged in, and will vampire drain below 90% in a matter of days.
Sitting near 90% is no big deal and there’s no evidence to suggest it is.
I was assuming it was at the body shop and wouldn't be plugged in, or not dependably plugged in. If not plugged in, it won't stay 90% for very long, and you don't want it running down to zero.Daily is one thing. Leaving it that high for weeks with out using it, isn’t great for the battery.
My experience with body shops is that they don't just leave it parked for two weeks and then work on it for 3 days. They do a bit each day or two as the parts come in and/or staff is available. So they'll be opening the doors and moving it, which means it won't go into deep sleep. I'd count on minimum five miles per day.If it runs from 90% to 0% in 2.5 weeks, with everything off, you’ve got major problems.
It should average 1-2% a day.
Agreed but that's not what's going to happen in this case, and 90% isn't high. If it was, it wouldn't be in the daily range.Leaving it high to long is just as bad as letting it get to low.
What about two months on an extended vacation? What should I do with my X?
We can argue if 90% is in trip or daily. Trip isn’t 100% only is it, of course not. So what is the the “range” to use for trips? It’s 90 to 100. And for that matter 100% isn't recommended at all, unless you really need that range and immediately use it. For “normal” trips you should use 90%. Some super chargers now limit you to 80%.
90% SOC is high. At least it is in my book.
My AWD still shows limited regen due to high SOC in the middle of summer at anything above 80% SOC.
