I have a service center appointment for a major issue on a few month old model X. The 2nd row seats are stuck down and unresponsive.
My service center is 1.5 hours away. So, I had been holding off on minor issues to have them remedied all at once. When I talked to the service center they said I was only allowed 6 issues per visit.
Here's my list. Has anyone else run into this?
- 3rd row air does not blow even on highest setting (no picture)
- Drivers side rear mini window lower plastic piece loose
- Rear passenger Door rubbing
- Drivers side front mounding sticks out creating wind noise
- Drivers side front of door seal needs glue
- Sticker marking on 3rd row passenger seat
- Paint run spot on drivers door caused rubbing and needs touch up
- Passenger side DRL crack. It is hard to notice unless the lighting is right and there are no signs of impact. It’s likely a hairline crack from install.
- Moisture intrusion on front windows in the rain. It seems the same spot is creating extra wind noise. Slight pressure from the inside on the trim creates a seal and prevents both
- Passenger side lower carpet coming out (tried just pushing back in)
- Rear drivers side seat cover won't stay attached at the bottom.
