little Roadster mysteries
Discussion in 'Roadster' started by tonybelding, Mar 28, 2015.
Tags:
  1. tonybelding
    tonybelding Active Member
    Hamilton, Texas
    Those little things that still puzzle me after having the car for a couple of months. . .
    I never did figure out what that thing was that I found stuffed behind the passenger seat. Re: What is this thing??
    I think the interior light in my Roadster is installed backward. When I tilt it forward, it shuts off. When I tilt it back, it lights up -- nicely illuminating the rear window, but the rest of the cabin not so well. Based on common sense plus my reading of the owner's manual, this seems to be opposite of how it's supposed to work. I asked the guys at the service center, but they assured me that "the way it works is counter-intuitive". They also claimed they checked another Roadster, and it worked the same as mine. So is it the manual (and common sense) that's wrong here?
    Why does the rear compartment -- outside of the gasket-sealed trunk space -- collect so much dust? Sheesh! Even short drives on seemingly non-dusty paved roads put a layer of dust on the PEM, ESS and the top sides of the wheel wells. Driving over a dirt road really poured it on. By comparison, the front of the car, under the hood, doesn't collect dust at all.
    Is the battery cooling system really supposed to be this noisy? The intensity varies, but over the last few days it's had a few episodes of really buzzing. Today somebody was asking me about the car. . . "Does it have a four-cylinder backup generator?" "No, it's all electric." "Then what's that sound coming from the back?" :p
  2. AEdennis
    AEdennis Active Member
    The loudest part for our car is when it is plugged in and starts to charge. It uses the PEM and is LOUD
  3. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    I can understand why the top of the ESS and PEM gets dirty, as there is no seal around that area in contrast to the seal around the trunk space opening. But like you I have been surprised by how clean the front area under the hood stays. Maybe it is because the front cooling fans suck in air with so much force that all the loose dirt and dust is pulled past those surfaces and pushed back around the motor, ESS, and PEM?
  4. gregd
    gregd Active Member
    CM98
    It's noisy when charging in a cool environment. If it gets warm enough (seems to do this pretty easily), then the Air Conditioning kicks in. Then it's LOUD.
  5. spaceballs
    spaceballs Member
    Sammamish
    if you notice the water pump being noisy make sure your topped off for coolant.
  6. sethr
    sethr CPO Roadster #1089
    Fairfax, VA
    #6 sethr, Mar 29, 2015
    My light is backwards from the manual, too. I don't use it, so I never asked if it can be turned around.
    If you are hearing more noise than usual from the rear fans, check that there isn't some debris in the fans - I get that from time to time. Amazing how much extra noise a leaf or two can make as it spins around in the fan housing. Those fans are blowing all that dust you noticed, too. Air pulled from outside is pushed by the fans through the PEM, out at the top. Some owners have put in filters - do a search, there is at least one thread on the subject in this forum.
    I don't have anything like your mystery object in my Roadster (a 2.5). No idea on that.
  7. supersnoop
    supersnoop Tesla Roadster #334
    Pflugerville
    When I purchased a used BMW 760, I found some strange parts in the trunk. Eventually, I identified them as a rear bumper insert from a Mini Cooper. I have no idea why they were in my trunk. I'm going to say that those extra parts are completely unrelated to you car.
  8. tonybelding
    Hamilton, Texas
    Where are these fans, anyhow?
  9. sethr
    Fairfax, VA
    #9 sethr, Mar 29, 2015
    You can see them by looking in between the back of the rear wheel and the fender, (there's one fan on each side):
    If you have some sort of grabber, you can pick junk out of there pretty easily. I have a whole lot of sand in there, I have to vacuum that out. Our roads are still a mess here, as you can see.
  10. hcsharp
    hcsharp Active Member
    Vermont
    We live on a dirt road in the summer and I usually have about 1/4" of dirt on top of my rear pan by the end of September. And the door sills? If it rains they are covered with a thick layer of mud. If it's not raining they are covered with a thick layer of dirt. Every day.
    Just to clarify, the loud sound coming from the back is not battery cooling, except for the circulator pump. The battery cooling makes a lot of noise at the front of the car where the air conditioning fans are. Around here you never hear that noise in the winter.
    Be mindful of the sound of your rear cooling fans (which cool the PEM and motor). I've had three of them replaced under warranty. The bearings go bad easily as you can imagine with all the dust blowing around. If it gets real noisy it might be a sign that your bearings are going. If you don't have the snow dam you should be able to reach in there and spin them easily by hand. If the bearings are bad they will spin hard.
  11. ecarfan
    San Mateo, CA
    So here's a Roadster "mystery" to me: I've noticed little bits of dirt/grit on top of my passenger side door sill after a drive. This is with the windows up and driving solo (so passenger door was not opened before, during, or after the drive) on paved and reasonably well maintained roads and highways in the San Francisco Bay Area.
    Could that indicate that the door seal along the lower edge is not doing its job?
  12. m0rph
    m0rph Member
    Belgium
    My "mystery": Every now and then, I suddenly find a layer of strange dust on top of my dash.. I'm sure it was not there a few hours before so it happens very suddenly. My car was detailled just 2 weeks ago and now my dash looks like I didn't clean it for a year :S
    The front area is kept clean by the fans I think. Sometimes, when I just start charging, it really blows a cloud of dust over the rest of the car. I sometimes think it can be related to my own mystery, but during winter my top is always on, so maybe the front fans blow that hard that it reaches the interior of the car somehow.
  13. Chillout
    Chillout Member
    the Netherlands
    #13 Chillout, Mar 30, 2015
    All of these mysteries should get a spot in the Wiki.
    My mysteries:
    - Several unused cables in the headlight area.
    One is used for Side markers on the non-Euro version. The other is probably there for foglights that never came.
    - Unused USB connectors on the left side of the dashboard.
    There is an operational USB port on the right side, but there's one on the left as well... although that one doesn't do anything.
    - The spoiler was not connected with all 4 bolts, only 2.
    Probably someone at the factory was lazy
    - The arm that holds the hood is wrong
    It is just wrong...mirrored 180 degrees from what it actually should be like.
    - Locking the car when you've just closed the door: surprise...
    just try it ;)
  14. Habious
    Habious Member
    Springfield, VA
    OK, I didn't want to say anything...I thought it was just me to that was too dumb to figure this out.
    The arm that "holds up the hood" on my 2.5 just flat-out doesn't work. It's either too long, the wrong shape, etc.
    There's a very nifty little notch in the hood that looks like it's perfectly made for the arm to go into except...there's no way to get the arm into it unless I bend the hood forward past its breaking point!
  15. ecarfan
    San Mateo, CA
    I think that is the case for all Roadsters, according to a Tesla service person I spoke to. My 1.5 has the same hood stay issue that you describe.
  16. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    the sound proofing stage 2 adds a rubber gasket that greatly reduces grit on the sills. But I hear it is now hard to get installed as it takes a lot of scarce labor. It s daunting for a do it yourself as you need to drill at least 4 holes in the bottom of the door which is permanent.
  17. bart513
    bart513 Active Member
    East Hampton
    There is someone who sells a DIY kit that works great to keep most of the grit away from the sills. PM me for more info.
  18. JohnGarziglia
    Reston, Virginia
    Here is the posting on that subject which I did about one year ago. I am pleased to report that after installing the plastic mesh around the fans, I have not experienced a recurrence of unbalanced fans to date (and here's hoping it stays that way as fan vibration is quite annoying as well as likely leading to premature bearing failure): PEM / Motor cooling fan filter
  19. m0rph
    m0rph Member
    Belgium
    Mine works fine here..
  20. Chillout
    Chillout Member
    the Netherlands
    can you take a picture of that?
