Which software version?Had to do my first reset in 2 months. Heard from Ohmmu that they are close to having a new version.
I'm assuming you mean Tesla software / firmware? It is 2022.24.8Which software version?
What firmware version? I'm on FSDBeta 2022.20.17 waiting to do a swap when more data.I haven't had any errors in my V3 for serveral days in a row but Sean just sent me a V4+ to test with so I swapped it out and now running V4+
So far so good. I'm waiting on the companion app that talks to the BMS. Sean said it shouldn't be much longer on getting that out to us but to not wait on installing and testing with V4+ so that's what I'm doing now. .
On a side note. The V4+ weighs only 8lbs. My former V3 battery was a tad over 11 lbs.
I'm still on 2022.24.8 since 9/9What firmware version? I'm on FSDBeta 2022.20.17 waiting to do a swap when more data.
Lots of questions with this app. "Enable Charge/Discharge"? Advanced? I like it. But any messages yet and if so, is it resettable using the app?I recently checked the App Store to see if maybe the OHMMU app is available and lo and behold here it is and this is what it looks like when you connect your battery to it on the V4 plus
I agree not sure what all this does yet and fwiw I sent Sean an email. Hoping he might get a chance to help us figure out what we need to know in using this.Lots of questions with this app. "Enable Charge/Discharge"? Advanced? I like it. But any messages yet and if so, is it resettable using the app?
That is way cool!
I see in the app store it says "This app is also used to perform battery resets and will be used to reprogram BMS settings in the future." I have a V4 sitting on the shelf and have requested the V4+ to test against then latest FSDBeta software. I also asked if they are collecting the data for analysis. If total voltage is 13.3V this may work. The V4 (non +) was at 14+ volts and the car rejected it after about 6 hours. The resting voltage of 13.3 may be close enough. I've been running a DiehardEV battery in the interim. It's an AGM and it settles around 12.9. I'm curious how a reset takes place. The Voltage button on the bottom - is this to select graphical?
