I am looking for some ranges for the model 3.
Any actual numbers would be much appreciated.
Maybe someone has access to this info in the service manual. If it is even in there at all.
Or maybe someone has a recent alignment printout I can look at to get the ranges I need.
This is what I'm looking for -
Left wheel base(mm) -
Right wheel base -
Front track(mm) -
Rear track -
Front Axle
Total Toe(mm) -
Total toe tolerances -
Camber -
Camber tolerances -
Caster -
Caster tolerances -
Included angle -
included angle tolerances -
full steering angle -
Steering difference at 20 degrees -
Rear axle
Total toe(mm) -
total toe tolerances -
camber -
camber tolerances -
I can math the included angle if you have the SAI.
Thanks!
Right wheel base -
Front track(mm) -
Rear track -
Front Axle
Total Toe(mm) -
Camber -
Camber tolerances -
Caster -
Caster tolerances -
Included angle -
Rear axle
Total toe(mm) -
camber -
camber tolerances -
Thanks!
