Will do!Thanks for the photos.
Can you measure from the ground to the fender both front and rear and again in 500 miles. Curious if it'll settle and drop further.
I haven’t got an alignment yet. It has a little negative camber. I’ll eventually get one.How's alignment with the springs?
Touché! Much better lowered. I added 15/20 mm spacers for the time being. I think the PUP can’t fit the 15mm without modification.Well done!
Can you provide more details on the spacers? What does the spacers do and why I might need them. I am thinking about lowering my PUP+ DIY install.Touché! Much better lowered. I added 15/20 mm spacers for the time being. I think the PUP can’t fit the 15mm without modification.
Haven’t done an alignment yet. Not many cars have adjustable camber, stock. UPP and MPP have rear camber arms for $400 and front a arms for well over $1000!! Not cheap at all. Alignment shops can get your toe back into spec which is more important. I didn’t measure the height before I lowered it but it really is just a moderate drop. If you need any measurements let me know.Looks great! I am also considering lowering with UP moderate springs and want to see what they look like on my LR. Mine happens to also be white color so your post provides awesome perspective. Have you done the alignment yet? Were they able to get the camber corrected? I know they are still settling, but how many inch drop would you say it is on the front and rear? Thx for your post and pics!
Spacers for the most part are for aesthetic purposes to get your wheels flush to the fender. Nobody likes the look of a sunken battleship! Spacers also can be used on a high offset wheel that might hit suspension components.Can you provide more details on the spacers? What does the spacers do and why I might need them. I am thinking about lowering my PUP+ DIY install.
Top is the front and the bottom is the rear. Hope this helps!
