I have a 2018 LR AWD and have noticed a fairly drastic recent range drop after a relatively long period of stability. The graph below is from the last 8 months from when I started graphing with teslamate. As you can see I was hovering around the 290 mark for a months until around 6/22 where I dropped off to around 275. This is during the summer in GA so cold is not a factor. I haven't been driving alot during Covid so this could be attributed to reporting errors in the BMS. When Covid started I set my charge limit to 50% but have recently moved it back up to 80% where I normally charge to. I'm wondering if I'm not charging high enough to let the BMS balance the battery and with only short runs during Covid I may not be allowing the car to do what it needs to do. Any ideas?
