Hi, picked up my 2020 M3 SR+ on 9/4.
I have charging at home using the supplied 5-15 adapter and was charging at 1 mile of charge per hour.
I was expecting between 3-6.
I just received my 14-50 adapter. Upon 1st use, I noticed the charging amps on screen read 16/32 amps. Less than 1 minutes into charging session, I received an error message, the car stopped charging. I removed plug from car, waited about 10 minutes, and tried again with same results. I called Tesla and they said there's a couple of different settings for the onboard AC to DC charger. I thought it might be the mobile charging cable, so I went back to Tesla and swapped charging cable, and had same issue. Bringing var to the shop and I'm hoping this is a fairly simple fix.
I did use a Supercharger and had no issues. Anybody else have this problem? Thanks in advance for your comments/help.
