I tried and it never worker, still drops too low.You can adjust mirrors in reverse and it will be saved to your profile automatically
It seems there are a few issues on the Y here:You can adjust mirrors in reverse and it will be saved to your profile automatically
Hi,
When auto tilt is off, nothing changes (that’s ok).
When I turn auto tilt on and switch to reverse, both mirrors tilt.
However - when I switch back to drive, only the left mirror tilts back. The right mirror doesn’t.
Anyone else noticed this issue?
You might check out this if you haven't already seen it ...I have been having a lot of problems with getting my mirrors setup to minimize blinds spots. I am going to have to test to see if this is related to the mirror problem.
Thank you for being helpful, but I had seen it and called in a service call. The Mobile Service Tech, came out and rather than clipping the posts said he bent them back as this was "safer". It improved the visibility immediately. He was still here and even helped me do the mirror setup that is in this and other threads to eliminate the blind spot. I was very pleased. I was still not confident that I could see the 48" tall low sports car immediately next to the passenger side (e.g. MGB, Tesla roadster, Lotus Elan), but it was close as I adjusted the mirror to point as low as I could and still eliminate the blind spot. Typically this means I see the wheels and lower body panels of the cars next to me with the view opening up more as the cars get further back. However, it either it didn't last or something else is in play because the blind spot seems to be back especially at night. Thats why I tend to drive with the rear camera view on.You might check out this if you haven't already seen it ...
2021 Model Y Sideview Mirrors Limited Adjustability
I have the same issue with my M3LR. I adjust them, save my profile and the next day again dropping too low. Also refraining from using tilting them works only for one day, the next day they drop again.I tried and it never worker, still drops too low.
I have stopped having problems with my mirrors when I turned of auto tilt.I have the same issue with my M3LR. I adjust them, save my profile and the next day again dropping too low. Also refraining from using tilting them works only for one day, the next day they drop again.
Still not fixed?
I can turn it off but the next day auto tilt is working again. Drives me crazyI have stopped having problems with my mirrors when I turned of auto tilt.
Did you save your driving profile after turning auto-tilt off?I can turn it off but the next day auto tilt is working again. Drives me crazy
I think I gave up on it.I have the same issue with my M3LR. I adjust them, save my profile and the next day again dropping too low. Also refraining from using tilting them works only for one day, the next day they drop again.
Still not fixed?
Yes. Too bad but I will have to live with itDid you save your driving profile after turning auto-tilt off?
I agree completely and it is annoying.I feel autotilt goes too low, wish I could adjust not to go that far
One thing that might be worth trying is to set the car to park, and then take the mirror (or both mirrors if they are both affected) through the entire vertical range of motion a couple of times. In other words, scroll all the way up until it won't go further and then scroll all the way down until it won't go further. Do that a couple of times, then set the mirror to where it should be and save the profile.
I had another issue with the seat back of the Model Y not adjusting when switching profiles even though all of the other movements were happening. I was able to resolve it (it has been almost a year, since with no issues) by taking the seat back all the way through it's range of motion a couple of times. When I then selected my profile it went all the way back, but then when I adjusted it after that and saved the profile it worked perfectly fine afterwards.
The only explanation I can think of for this is that there is a controller responsible for knowing what the position of various seat components are at any time and in some scenarios that can go out of calibration with the actual physical position of the seat. It seems that moving the seat element through the entire range of motion effectively recalibrates that range of motion for the seat element.
