Mirrors Tilt Adjustment
Yes, it can be very easily done.
It doesn't work, you can reproduce by trying the following:
  1. Make sure you have the Mirror Auto-Tilt option enabled.
  2. Switch gear to R, the mirrors will tilt down.
  3. Go to "Controls" and adjust the mirrors while the gear is still in R and the mirrors are in the tilted position.
  4. Press "Save".
  5. Switch gear to N and the mirrors will un-tilt.
  6. Switch gear to R - the mirrors will tilt but not to the position that was saved in step (4), they will just tilt to a default tilted position that it appears cannot be changed.
Reactions: Depwraith
  4. Press "Save".
I have the same problem
