hacer
See this Model S Gen2 Charger Efficiency TestingHow do you see charging at 25 vice 48 amps as more efficient?
My link was to a specific post of mine in that thread, which itself linked to a plot and explanation, as well as the raw data. Since you didn't follow the second link, here it is only one click away: Ideal Charge Rate?? in summary, the new chargers (48A/72A) are more efficient overall and, from data that I've gathered, have a peak efficiency at 25A (almost as good at 35A too). The charger is ~1% more efficient at 25A compared to 40A, and ~1.2% better compared to 48A. Since this charges the battery at a lower current, presumably the (unknown) efficiency of the battery is also greater. Finally, there should be less stress on all of the components in the system, so if you have the time, why not? I think, but have not proven, that in very hot weather the lower charge rate is also less likely to provoke operation of the cooling system. My car has the new charger so this applies to me, but it is different for people with older cars.Thanks. The initial post in the thread appears to indicate that the chargers are most efficient at 40 amps. ...
I did see the link one poster put later in the thread to his testing (Ideal Charge Rate??) but that appears to be based on using the UMC vice a HPWC and his biggest concerns are the heat of the UMC cable running at 40 amps and leading to cable breakdown or early UMC failure. Even with is numbers, the difference in efficiency is about 1% meaning almost negligible for an almost 50% decrease in charging speed.
Guess I'm missing something...or is this all about charging with the UMC and trying to balance out the heat issue?
...My point remains the same. Your data only shows a 1% increase in charging efficiency for an almost 50% decrease in charging rate. Why would you do this? To save money on your electric bill or something else (heat concerns). That's what I don't understand.
which I took to mean how is it more energy efficient, but I can see that you might consider time efficiency. So now I understand your question.drklain said:How do you see charging at 25 vice 48 amps as more efficient?
