Model 3 Jeda Wireless Pad
Discussion in 'Model 3' started by tropical1, Aug 4, 2018.
  1. tropical1
    tropical1 Member
    Odessa, FL
    My daughter and I created a video unboxing and setup of the Jeda wireless charger for Model 3.
  2. BobAbooey
    BobAbooey Member
    usa
    How has the charger been working for you. Anything you dislike about it?
  3. alfadur
    alfadur Member
    Chapel Hill, NC
    Jeda works very well for me, no problems with installation or charging whatsoever. I did not get the fast charging addition, and it still charges quickly.
    Some nits though:
    • The back of the charger doesn't have the indentations that the standard rubber pad has, instead there are sort of sticker things that you can peel off. I didn't do that, so the charge moved slightly (<2mm) the first few days. Now it's pretty stationary.
    • I chose Jeda in part because my wife doesn't have a wireless charging phone yet, so I wanted to keep the plug charger on the right side and wireless on the left. This works in theory except her phone can't easily get to the standard plug, so I had to sort of unhook the plastic bit on the front of that area to get it to work. Now it's fine, just not ideal.
    At the end of the day, the charger is great. My phone doesn't slide around while on it, and it starts charging pretty immediately when I set it down. Would definitely purchase it again.
  4. BobAbooey
    BobAbooey Member
    usa
    Cool, thank you for the review I think I’m going to order it
  5. SeasonedTech
    SeasonedTech Model 3 Dual Motor
    Benicia
    I’ve been using it for a couple weeks now. No issues, pad doesn’t move and phone stays in place - even with my occasional quick accelerations and racetrack like turns. I measured the current draw for each side ~1.03A. I also have a USB splitter (cable only, no hub) for the USB flash drive to support the dashcam. I recommend it!
    Splitter from Amazon
